Tundra OEM coil isolator required for coil swap?
01t4rnr
I posted question earlier but had it worded wrong. Ive got the TRD Tundra coils headed my way and plan on running the BE5-6929 adjustable 5100 Tundra struts on my 4runner. Already have longer studs and 3/8" spacer from my current Revtek kit. Is the only other thing ill need Tundra coil isolators or do i even need them? Thanks!
i just used my stock ones on top of my old man emu lift, i would imagine it would be the same, at i'm not sure if the holes will line up using the tundra puck at the top,i don;t know for sure, but i'm going with no just use the one thats on there now.
Reviving an old thread for the same issue.
The tundra isolators aren't needed correct?
My tundra coils are on the way and I don't know if I need these or not. I'm thinking the 4runner top hats and isolator will suffice but I don't know for sure.
I've heard of guys using the 4runner isolators, so you should be good. I think mazer was using the 4runner isolators as well.
