4RunnerChaos
So I have a question for anyone out there who has experience with turbos
I've seen in a few pictures where guys run a twin turbo setup where the down pipe runs right into the compressor housing of another turbo... I like the idea of this but I'm not sure how that would effect the spooling of the second turbo.... Or if the run a smaller turbo for the second so they both spool up and produce the same amount of boost at the same time.
Or B run a larger turbo as the second turbo that will start to spool and be able to keep the boost in the higher rpm range when the smaller turbo can't keep up...?
I feel like either way would work.
If the latter of the two options would work, I was thinking of attempting something like that, rear mount where the cat currently is using a GT25 turbo in front of a larger turbo to prevent the turbo lag. The gt25 would start building boost almost as soon as you start on the throttle and once it hits the say.. 10 psi the wastegate would open up relieving the pressure on the small turbo and continue operating the larger turbo.? I understand this would take a lot of engineering and dyno time to keep from blowing up a turbo (or worse yet an engine)
Any thoughts ideas links pictures or personal experience would be greatly appreciated. But please don't do the "my buddy's cousins friends uncle ran eight sequential turbos on his 350 sbc ran over 60 psi of boost and made 3000 hp" comments. Thanks
