I disagree, a V6 suv can be fast. Plus whats wrong with being different and standing out from the rest? Anyway the hardest parts are going to be fabbing it up and tuning. Tuning being the tedious part were your dealing with open and closed loop modes, AFR's, EGT's, fuel trims, timing, etc. you'll want to have wastegate control that has the ability to keep the boost below a curtain level to avoid compressor surge. You'll also want a good oil feed system for your turbo and a good EOC to keep you oil temps low. And while yes you might be limited by your stock internals its the power curve where you will see a difference. Turbos don't have the parasitic loss that superchargers suffer from. You will have turbo lag, yes, but if you size up your turbo just right you will very minimal if any turbo lag.
