live4swell
Member
For those of you that have Bridgestone Dueler A/T Revos particulary the size 265/70/17, what tire pressure are you guys/gals runnin? I used to have my dunlops at 32 psi and so far kept the duelers the same but I wanted to see if you changed pressures or not. Then, is something wrong with my alignment where the tires are different distances in the front. Let me explain...On the driver side the tire is closer to the mudflap and on the passenger side it is closer to the front plastic. I would think both sides should be the same. I also measured the distance from hub to hub on each side and the driver side is 100 inches or so and the passenger side is 110, showing that the passenger side tire in the front is closer to the front. Should I get a re-alignment? I noticed this now due to getting new rims and tires put on. Any insight is appreciated thanks
