Two Questions: Tire Pressure and Alignment
live4swell
Member
For those of you that have Bridgestone Dueler A/T Revos particulary the size 265/70/17, what tire pressure are you guys/gals runnin? I used to have my dunlops at 32 psi and so far kept the duelers the same but I wanted to see if you changed pressures or not. Then, is something wrong with my alignment where the tires are different distances in the front. Let me explain...On the driver side the tire is closer to the mudflap and on the passenger side it is closer to the front plastic. I would think both sides should be the same. I also measured the distance from hub to hub on each side and the driver side is 100 inches or so and the passenger side is 110, showing that the passenger side tire in the front is closer to the front. Should I get a re-alignment? I noticed this now due to getting new rims and tires put on. Any insight is appreciated thanks
Wheelbase
The published wheelbase of a V8 Sport 4wd is 109.8". I can't imagine that there is a 10" diff. That would indicate a severely bent frame. Carefully remeasure, and I think you'll find both sides are the same. Let us know what you find, and how you like the Revo's. I have a set on order for my 04 V8 Sport in 265/65/17 (OEM). Can't wait to get rid of the Dunlops, with winter coming.
:dunno:
Sorry...I just realized I had a typo. The driver side was 110" and the passenger side was 110.5". So i was concerned with the .5" difference between sides. I also do not know the accuracy since I am trying to go center to center of the rims and it might be more accurate to do with the wheels off the truck. But as far as consistency I measured from the same spot on each rim or atleast tried to. I just dont know if it is normal for the two sides to have slightly different measurements. If you can do me a favor when you get a chance could you measure on yours center to center of each side and see what yours is? Thanks
