is there a reason why you didn't weld the bottoms of the mounting plates for your sliders. also i don't see gussets for the legs either. my dom sliders still bent after i landed had on a boulder, and mine are 1/4" mounting plates with 1/4" gussets.
I see, I guess you can always cut some gusset outta scrap if you need to.
I love that your dad was stick welding. So awesome to see it being used. I've thought of getting a stick, but they aren't the easiest to fab with.
That looks sick. Rignis armored head to toe man. Time to hit some trials
yup.. thata the bumper im gonna get. shockworks what???? looks freaking sick CBI killed it with the design
Just an FYI unless they decided to adopt the design as standard that isn't the normal full grill guard. I asked them to create the shape of that one the way they did having the outside hoops taper down towards the center. I sent pictures and drawings of a few other bumpers with hoops that way as example of what I wanted.
One of the best features is that it is high and tight with good clearance and approach angles yet I was still able to drop a large 10k winch in by myself after the bumper was already mounted.
Hope everyone had a great Thanksgiving week last week. Just a small update.
I picked up a Harbor Freight 20 Ton Press with plans to do my own bearing and hub pressing for my manual hub conversion. Toyota quoted me minimum of 2.5 hours labor and I couldn't find a shop in the area that someone I know recommends. Will post pictures of the process when I get it setup and do the work.
20 Ton Shop Press - Hydraulic Shop Presses on Sale
