Awesome build. I wish i had the time and $ to do just some of what you did. Looks great, love the color.
Thanks. I'm honestly not sure it is a rational project but it is a project.
Tonight I started working on the dash a little. The truck had some wood added beyond the standard limited wood trim. Over the years the clear coat had bubbled and become yellowed in spots. It delaminated in many areas too. I thought it to be real wood but it turns out to be plastic like the factory wood. Anyway, I sourced a matching replacement kit through Burtman Industries, you can find info earlier in the build thread.
So, here is the scoop:
BEFORE
SIDE BY SIDE
AFTER
Here is the basic process (DONT FOLLOW THIS METHOD UNLESS YOU ARE REPLACING WITH NEW PANELS)
You heat the panel with a hair dryer or heat gun. I'm using a heat gun but you have to be careful not to melt something. I'm using it on low. Anyway once warm the panel becomes pliable. Using a small flat head screwdriver start to separate the panel from the dash
Work your way around until the old panel pulls off
This is what is left behind. 3M Adhesive.
You get the adhesive off by heating it and slowly rolling it off the surface with a flat item like a screw driver blade
Next up is to clean as much remaining bits of adhesive off as possible. I used some goo gone and a dry rag. This is the passenger side but gives an idea of about how clean I got them.
Here is the finished passenger side. Drivers side shown above
Started working on the pieces surrounding the steering column but had to stop to go watch Gold Rush.
And here is why I say don't use my method if you are not recovering it with new trim. It eats up the underlying finish getting the old 3m adhesive off.
Lastly I have a set of new light racing upper control arms inbound as well as the new toyota lower control arms so my entire front end is going to be starting fresh to last me hopefully 16 years like the original parts made it.
