txbonds
Senior Member
Dropping the Sonoran diff drop out and jacking the diff back up with spare jack did the trick on the large steering rack bolt.
Drop kit removed. Only problem is one of the top washers dropped down into a hole in the cross member that runs right there. Not sure how I'm going to get it out yet but will come back to it when I have the drivers tire mounted and I can safely crawl all under truck.
Don't judge my wood 4x4's as I only used this small jack to lift the diff up. Truck is sitting on jack stand with floor jack also there as backup.
Blurry picture, but you can see the empty bolt hole in the back right and the diff next to it. That was the culprit bolt. Getting it out gave me enough wiggle with the steering rack to wiggle the cam and bolt out of the LCA. I put steering rack bolt back in partway backwards to just hold the steering rack until I'm ready to swap bushings.
Where I stand right this minute with new LCA hanging and lightly tightened to hold CAMS in place on paint marks I made. Will need to be torqued still.
Up next is the light racing UCA.
