Undercoat rust protection
Heckler45
Junior Member
Anybody here familiar with Patriot Rust Defense undercoating? I am curious how it compares to Fluid Film. Also, wondering the pros and cons of lanolin based Fluid Film vs the solvent, asphalt, and wax of the Patriot stuff? Any info would be greatly appreciated.
Thanks in advance!
First I've heard of them, their product sounds like an almost rubberized undercoating maybe?
Reseller/applicator description: Underbody Rust Prevention in Quincy Illinois
I'm a huge fan of Woolwax as it can be safely applied to everything metal, rubber, or plastic unlike Fluid Film which will slowly dissolve your CV boots.
I have no experience with the one you listed, but I jut started experimenting with the Blaster Surface Shield on my Polaris XP900. Although I live in a relatively rust free area (South Texas), I plan on coating my underside with Surface Shield for the title surface rust I have.
Fluid Film, is bad for rubber?
Yes, per their website it will cause non-oil resistant rubber to swell, and soften.
It is still a good product, just have to be careful when applying versus Woolwax which can be sprayed on anything.
Asphalt based-Patriot- coatings can trap moisture under them and you will never know. Use Fluid Film black if you want that look.
Ambrose67
