UPDATE! 5th Gen 4Runner Q&A Series - Questions
1engineer
Moderator
If you clicked into this thread please read this http://www.toyota-4runner.org/5th-gen-t4rs/226519-5th-gen-4runner-q-series-introduction.html first. This is the Q&A Question thread. Please post any question you may have about the 5th Gen 4Runner here, even if it has been asked or answered many times before! Tires, wheels, drivetrain, suspension, interior, Entune, speaker install or anything else. We will go through the questions, pick the most pertinent ones and start answering!
UPDATE:
The first topic our group will address will be lifts and tire sizes from a total novice point of view. We will discuss, in steps, what is required to lift and run plus size tires, from all different lift options all the way to keeping your tires from rubbing. We will also discuss all the pros and cons of each phase of the lift and lift kits from spacers to Icon Stage XXX.
This is going to be quite a project so different team members will take a certain portion of the process, write it up, have the rest of the team review it for content and then we will publish. I listed the team members in the other Introduction post ( some really smart guys) so be sure to thank these guys! Hopefully we can have something that will be a peer reviewed guide for the 4Runner Lift and tire upsizing. I will keep you guys updated on the progress in this post. Now [MENTION=68685]Ducmonsta[/MENTION] and I need to complete the outline lol.
Is there a supercharger available? When will it come out?
Seriously, there needs to be one place that has the answer for this with a concise response.
Why aren't there enough cup holders in the 4Runner?! I NEEDS TO KNOW.
But seriously:
1. Explain the relationship between multi-terrain select and how it relates to the ABS system and your gearbox.
"Will my 4runner be okay towing my trailer with XXXX weight?" Address proper trailer weighting, anti-sway devices, transmission cooling questions, gear selection, rear suspension airbags/bumpstops, etc...
Would also be nice to know some variables such as which wheel offset is least likely to get you rub on the 4R (stock wheels) vs running aftermarket. How spacers affect this dynamic, etc.
Nevermind fitment, I want to know which one is best :smash:
One of the first things I wanted to know was:
What can I do about this nose dive (lunging forward when stopping)?
I will rattle off a few:
1. What is KDSS, how does it work, and what are the advantages/disadvantages to the system?
2. How do the 4WD systems differ between SR5, Trail/TRD, and Limited models?
3. What are the advantages and disadvantages of aluminum and steel armor?
4. Can I install HID's/LED's on my 4Runner? (this one should be fun)
5. What pressure should my tires be set to? (load rating specific)
6. "I have a Trail, with a lot of 4WD buttons. How do they all work, and when should I use them?"
That'll do for now. Thanks for putting this together, [MENTION=66316]1engineer[/MENTION]
Here are some with links for possible info to help out on answers if any are chosen for inclusion.
1. How do you exercise your 4WD when you cannot get off road?
2. Is there a floor mat for 3rd row seats?
Thread with info
http://www.toyota-4runner.org/5th-gen-t4rs/217710-3rd-row-seat-floor-liner.html
3. What front hitch receivers are available?
Info for 2016 SR5 in this thread
http://www.toyota-4runner.org/5th-gen-t4rs/213975-front-hitch-receiver.html
different solution here
http://www.toyota-4runner.org/5th-gen-t4rs/223977-front-hitch-31076-vs-31367-a.html
and another
http://www.toyota-4runner.org/5th-gen-t4rs/219587-cbi-front-receiver-hitch.html
4. Is there a simple cheap rear fog light solution
Thread with info
http://www.toyota-4runner.org/5th-gen-t4rs/213809-2016-rear-fog-light.html
I suppose another could be "Can I chip or custom tune my 4-Runner" since many manufacturers allow for this to happen.. and can often surprise new Toyota owners.
Regarding DuraTrac tires, why are the maximum speed, maximum load, and maximum air pressure, higher for the 265/70R17 SL then the LT265/70R17 C.
1. Best solutions/practices for pinsrtripe/clearcoat scratch repair.
2. Suspension upgrades based upon intended use...(on-road, fireroad trails, rock crawling, towing, all-around "overland"...etc.)
Why does my rig lean to the drivers side after my lift
Should I trim the fender/liner or lift my rig to keep it from rubbing with bigger tires.
Why does my entune not connect to play my pandora/ make calls/ reboot randomly
How does the elocker work
That's all for now. Not exactly my questions, just ones I've seen.
Sent from my SAMSUNG-SM-G890A using Tapatalk
To add onto Cymon's suggestion, suspension upgrades to address body roll/nose dive that don't lift the truck.
Since a common response to a thread started by a newbie is "Use the search function", maybe a sticky tutorial on tips and tricks for advanced searching might be a good addition. Say I do a normal search for "UCA installation" I get hundreds of hits on threads telling me how to install everything from LED bulbs to 3rd row seats. Just a thought for those that aren't so computer savvy.
http://www.toyota-4runner.org/5th-g...ner-owner-need-help-searching-start-here.html already stickied.
Jhunt
