Upgraded 265/75/16.do I need zero calibration
WHORERUNNER
Do our 4runners need the zero calibration done when replacing stock tires for taller ones? I've only read about zero calibration being done after people trying to pull codes.
Are you refering to zeroing the speedometer? You can check your speedo reading against a GPS device and determine if you need to re-zero. I would think you do have to do this, as going to larger diameter tires means less RPM for the tires at a given speed. Since the differential, transmission and t/c ratios haven't changed to compensate for this, your speedo will be off. Whether it is off enough to matter is another question.
Good point. Thanks
MaximussK
