trentj2007
I have a completely stock 2000 4runner (2wd) except for a cold air intake. Any suggestions on what I should do to it? I looked into making it 4x4 but it's just not worth it.
sound system, video system, jaos spoiler, projector retrofit, led tail lights, clear corner lights, tint, this is all for people that have 2wd and not into wheeling
what do you mean by wheeling?
Serious off-roading. Crawling rocks, mud, rough terrain etc.
2wd can get a lot of places, but for anyone serious about trying to make their rig more capable off road, IMO there is no point in starting with anything other than 4wd.
If that's what you're going for, save the money you'd spend modding until you have enough to sell your 2wd and combine the cash and buy a 4wd.
Sorry to rag on 2wd but when it comes to off roading, it's like if someone asked me how to go about drag racing their civic. I'd tell them it's an inherently bad place to start from.
Ahhh, "low range envy". All this stuff about 2wds keeping up with 4x4s is true as long as you're on a pretty flat road and only need 1/2 as much traction. But, I can assure you, a 2wd won't cut it on anything but fire roads around here.
The fact that 2wd doesn't have low range means that you will not have the climbing power to get over steep obstacles - period.
A locked 2wd will even the field a little, but low range is the big difference that sets 4wd apart from 2wd. More so than traction IMO.
I would also have to agree, making a dragster out of a front wheel drive car like a Civic isn't a great base to start from.
My 2WD does better than some 4WD jeeps I've seen. I had to pull one out and then go straight through what they were stuck in. So a 2WD will surprise you for sure! But is's still not a 4WD.
Sorry but I have to disagree with you on the drag racing a civic thing...
My friend has a 94 civic with 800+hp to the wheels. And not to mention it is a lot lighter than a v8 car.
Why not? I did it to my 98 Taco in 2003 for around $1500 total. If you are even slightly mechanically inclined you can accomplish this. 2wd can't compare to the capability of a 4wd IMO. I've had experience with both.
-Trans w/Tcase $800-look at auto recycling yards
-CV/Front Diff/Vac lines/spindles $400 Look for someone who just SAS'd their Tacoma. They wont be needing the IFS stuff anymore.
-Front and rear 4WD driveshafts $200
-New center console piece $100
No special wiring and no need to worry about dash lights saying you are in 4x4. Shift into 4WD and go.
If you already have some money into your rig now and you don't want to try to sell and buy a 4x4, then just convert it. It really is very simple and there are tons of write ups about it over on Toyota Territory Off-Roaders Association (TTORA)
If you really don't want to convert, add a locker. Thats as close as you can get. But the 4WD Low range is still key as stated previously.
so it's really not that difficult to make it 4x4?
and what exactly does a locker do for a 2wd?
