Upgrading JDM smoked headlights
HRunner
[PLEASE READ THIS FIRST]
It is my first writeup and I am not a qualified technician. Therefore, you should only use it as reference. I am not taking any responsibilities and you
4) If you were at this stage, then you should be able to find the last screw. Now, you should come up and get a drink for yourself. You already passed the most difficult peak of the trip. Now we are going downhill.
5) Next, take off the cover piece that between the headlight and the bumper. Handle with care because you don
Nice write up HRunner! Some of these steps may be very similar if you want to try to update to the 2006 projector head lights. I've got nothing to back that up, just making an assumption.
HRunner
Great write-up, good job, that really helps out alot!
I do have one question for you though. That last headlight bolt that is hard to get to, is that the bolt that you can see from inside the fender well, there is a little round cut-out in the plastic fender liner, and if you look you can see a bolt head in there. Is that the bolt you are talking about?
You don't have to lay on your back to see it, like you said in your post.
Looks cool. Good write-up. I have 2 questions for you:
1. Do you have H.I.D. or halogen bulbs? Looks like the ones on your picture are halogen.
2. What about light pattern? If you used JDM ones, they should have different cutoff, because they drive on the left side of the road.
00328 said:
HRunner
Mm... you may try to take off the inner fender plastic, then you may able to access to the last bolt more easily. However, I looked at it and seem even more headaches to remove that inner plastic fender.
Let me "steal" Ryan's picture to explain.... that round cut hole shows in the picture couldn't get you to the last bolt. That's one of the bolt for the bumper. If you don't want to lay under the car, try to remove the bumper.... :D
1) It said H.I.D. on the box... however, it is a halogen :D The XD5 is 5800k and only 10 bucks a pair.... (fair enough to try it yourself)
Look at this thread... you will find more information....
http://www.toyota-4runner.org/showthread.php?s=&threadid=8462&perpage=15&pagenumber=1</a>
2) Yes you're correct! That's what I found after a test drive. You will need to adjust the aiming for the JDM lights.
iFORCE said:
:D how much did those JDM lights set you back? :artist:
I got them from my friend who's working as a broker in Japan. He's getting a very special staff price, like a bonus for staff once a year.
I don't remember exactly, but cost something like 30000yen (around Cdn$330).... I also got the JDM fuel cover with JDM cap.... and I am going to install it later :D
Damn you man, I'm jealous!:D You can't even get those here for under 800 dollars! I want those headlights like you wouldn't believe!
.........there's a late response. :p
