used car and oil leak question
palooka23
I have been shopping for 3rd gen T4Rs and Tacomas....but every single one I have seen has oil present on the undercarriage.
The latest one I have seen is a 2002 sport edition in fairly good condition. The owner is asking for $7700. I was prepared to offer 7500, but upon test drive, noticed oil smell and smoke.
My questions are these: how common are these leaks? How expensive to fix? Is 7500 fair for a truck with a leak? Are there any out there without leaks?
Thanks in advance
Very common. You'll just need to re-seal the valve covers. They leak from the rear half moons and drip down the block making it look like a rear main seal leak and then terminates on the steering rack. I would say to the seller, the rear main seal is shot. I will give you $7000. He may bite on it. The gaskets and rtv will cost you $50 and a few hours. Warning though, dont just go around a tighten them down. It will leak worse and you risk snapping off a bolt. Use a torque wrench to tighten the Bolts. It takes only 5 foot pounds (51 in pounds).
Thanks for the prompt response.
I did offer 7k. He immediately said no. He has responded that he will accept 7500. While I have worked on cars and trucks many times, I feel weird about buying a truck that immediately needs me to commit to fixing. Esp since I lack the tools and manuals needed to do so. I am sure I can manage....but not exactly ideal.
Should I consider having dealer fix? Obviously, I would be covered under some type of warranty if they did the work.
Thanks again.
Also, when you do an oil change the oil filter will drip some oil directly below where the filter is screwed onto, thus making it oily and appear to have a leak.
Thanks again.
I think the stealer will want about $400-$450 to do the valve cover gaskets. You can do it in a couple of hours. There is a good writeup with pics on here somewhere.
AlaskaRuss
