V8 starter click, click VOOORRROOOOOOMMMM!!
alia176
Senior Member
Fellas,
I believe it's time to rebuild my starter but wanted to confirm my symptoms before I tear into the intake manifold and all that fun stuff. Those of us with the V8s, have the "quick start" feature and this wasn't happening. For the V6 owners; we simply touch the IGN and the engine cranks on its own until starting. In my case, when I did this, I heard one click.
So, I went ahead and cranked the starter like a normal car, more clicks came then started right up. I did check the battery voltage during cranking and clicking and she is rock solid at 12.6 vdc. Battery is less than a year old so I expected this. Alternator is outputting 13.8 vdc during idling.
This didn't happen the rest of the day so it makes sense that the starter contacts and plunger need to be rebuilt. Vehicle has 340k miles and I can only assume it's the original starter.
Am I on the right track here?
It sounds like my old 1980 TOY PU, starter solenoid would crap out. Could tap/gently with a hammer to get it to start...this was when I was 16years old btw...back in 1986.
Uncle Toyota buried this starter in the V8 valley so no smacking with anything due to access :crybaby:
Replace the starter contacts. Getting the starter out is the hard part, but if you call your Toyota dealership you can get the two contacts for cheap.
H.Sikina
