vac system
gacrisp
Ok I have just replaced rotors calipers pads and freed up the back brakes, everything is nice and free. However now it stops worse than before the brake job. I was thinking the master or booster would be next and then started to check the vac lines. I have a haynes manual but need an exploded diagram of all the vac lines on a 1989 v6 3.0. Right off the bat I am finding hoses that are supposed to be in different places and some of them are so loose they don't work at all. But I can't find a nice diagram of the whole system so that I can make sure everything gets where it needs to be.
Anyone have anything like this?
thanks,
Greg
did you install it or did a shop do it? it could just be a shitty bleed, and still have some air bubbles in the lines, which turns the best brakes into absolute balls. you will end up having to stop fred flinstone style with the door open and your feet out it. i will see if i have a vac diagram tonite. but just try and tigten up all the hoses, but worse comes to worst, swallow your pride and take your car to a toyota dealer, or any good mechaninc shop and get it re-arranged. they know what they are doing and what you were doing wrong.
