Valve Cover Gasket Replacement
I think that the head of the 5vz was indeed used in another Toyota non US model, but I cannot remember offhand. Prado, Hilux?
It is worth the time to remove, clean and reinstall them with new FIPG when changing gaskets.
Not to steer this thread off topic, but I'm sure you all are familiar with the valve cover bolts coming loose. I first noticed this when I thought my valve cover gaskets needed replacement due to the amount of oil seepage. I realized that wasn't the case when I saw that the bolts were super loose for no reason. I find myseld having to retighten every few months.
Does anyone have any suggestions to get these bolts to stay tight? Maybe lockthread?
could maybe try mild strength locktite. I imagine just a little locktite would work.
Maybe something needed for the casting or machining process?
I always hope the engineer that specified something like this will chime in discuss with us.
I'm not the engineer that designed this head, so I am speculating.
I would suspect they are there so that the journal bearing lands for the camshafts can be line reamed to ensure they are all 100% aligned. I would bet the original casting has the journal bearing lands a bit undersized in the head casting, & the bearing caps are a bit undersized and then machined together to ensure a 100% perfect fit to the camshaft OD.
You wouldn't be able to ream them if that "half moon" was part of the original casting
Anyone took a side by side comparison between a new gasket and the old ? Aside from the spark plug tubes, would it be worth just cleaning and using rtv to repair the old seals ?
