I thought about ecigs when I was trying to quit, but I decided I wanted to be completely free of the addiction. I used Wellbutrin, and it had me quit in about a month. I've never looked back. Good luck to everybody trying to kick the demon weed, it ain't easy but it's worth it.
He's literally trolling for a fight, SV. Ignore him.
Hell, ban him.![]()
I have one of these vaporizer pens?
Don't you have puppies to kick around?
So, I started vaping a few weeks ago in an effort to quit smoking. If you're unfamiliar with it the. Here's a quick rundown. The mod (battery pack on the bottom) provides electricity to a coil that is fed fluid through a wick. When the coil is energized it burns the fluid creating a vapor. You smoke this instead of cigarettes. The fluids come in hundreds of flavors and some are quite tasty! I used to smoke about a pack a day since I was... Well... Too young. Since I started vaping 3 weeks ago I have smoked less than a few packs of cigarettes and have now been cigarette free for 5 days.
The contents of the juice you put in the tanks are not harmful and you choose your level of nicotine in these juices. Vaping has become a good source to stop smoking because of the two types of addictions to cigarettes. The first type of addiction is the addiction to the nicotine. Because you choose your level of nicotine, this solves the first type of addiction. The second type of addiction is the addiction to the habit of actually smoking a cigarette. Well, the form of vaping is similar to smoking cigarettes so this also checks that block too.
Anyways, I just wanted to see who else is doing this and what your results are to stop smoking, what setups are you using and what flavors do you like?
Here's my setup: vamo mod with a protank kanger tank. I'm vaping a blueberry juice and swapping between blueberry and Mountain Dew.
Isn't the easiest way to quit smoking to just not put a cigarette in your mouth and light it?
/obvioustroll
I quit after 27 years of smoking, no vapor, just patches and disere to be around for my son, surprisingly it was easier then I thought it would be.
if this sh1t help you quit then for all means do it.
I marked 3 weeks with no cigarettes yesterday. I'm using the iTaste MVP variable voltage box mod with KangerTech Protanks and TS3's. Using an RY4 flavor mostly from a local shop, Mountain Oak Vapor, as well as several other of their flavors. Really enjoying this!
I rarely have an urge for a traditional cig, and even when I do, it isn't strong. mixing strengths to step down on nic slowly. Goal is to get to lowest level and continue there for a while. I really enjoy this habit, and am glad I found a way to keep it, and not batter my lungs.
Keep it up! Vape on! Vape anywhere!
