Vibration solved
Gt4r
I've seen a number of threads with people complaining about vibrations. Just wanted to share what was causing my issue since I didnt see any posts with others having the same issue.
I was feeling a light vibration in my drivers side floor board when accelerating and when i got to around 1500 rpms. I thought it might be skidplates loose or heatshields. It ended up being too much slack in my parking brake cable. The cable resonated at a certain rpm like a guitar string. There is a adjustment and lock nut at the pedal. I adjusted the tension on the cable and it drives smooth as glass now. Just be careful with the amount you tighten it. I did also adjust the parking brake shoes.
Hope this helps anyone having the same issue.
fhgy0045
