Vibrations/Noise coming from under car, when gas is depressed...
itsgt
Has anyone had this problem before?
Does anyone know what is causing this vibration/noise?
Basically what happens is, after about 50-60mph on the highway....when I let go the gas paddle, there is a heavy vibrating feel and noise coming from under neath the car(under the seats, where you can even feel it sitting down).
I was able to rule out that it has nothing to do with the transmission by switching the gear into Neutral. Also ruled out that it was the engine, by turning the engine off during driving (mechanic did this part). I had the mechanic take a look at the drive shaft under the car, and he lubed it up, and i did wheel balancing. Mechanic saw no problem with anything else that could be a problem......I am on the verge of going to a 2nd mechanic to get a 2nd opinion, but wanted to run it by you guys before i go...
Any ideas would be appreciated!
