Victory 4x4 New Products/Prototyping
While you guys are on a roll , is a front bumper like this possible ? This one is made by C4 for the Tacos
Liking the products! Have you considered making a low profile light weight rear bumper with tire carrier? I'm liking what I am seeing so far and may be interested in some of the products down the road, as i'd like to eventually sell my RPMFab front bumper for something made by a much better company.
Roof Rack Now Available!
Our roof rack is now available for the 4th Gen!
This roof rack system allows for mounting almost anything, freeing up valuable cargo space for other trip essentials. Comes coated with a 2 stage satin textured black powder coat over durable zinc primer finish.
  • CNC cut and formed from 3/16" aluminum (steel mounting brackets) with extruded aluminum rails
  • Easy bolt together installation
  • No drilling required
  • Available with or without 40" lightbar cutout (light bar option on full-length rack only)
  • Lightbar cutout version includes light bar mounting brackets
  • Cutout fairing designed for 41.25" max lens housing width single row LED light bar. Up to 43.5" (mounting stud width) bar will fit with our mounts, but trimming of the fairing will be required
  • Milled T-nut access points
  • Sunroof tilt and sliding function works with racks
  • Fairing Edge Trim Included
  • Powdercoated
  • Hardware Included
  • Black stainless hardware available, see related products
  • Made in the USA
  • Free shipping!
4Runner Roof Rack | 4th & 5th Gen (03+) - Victory 4x4
Rear Window MOLLE Panel Now Available!
Designed to maximize the storage space in the rear cargo area. Offers customizable mounting for tools and gear. Comes coated with a 2 stage satin textured black powder coat over durable zinc primer finish.
  • CNC cut and formed from .120" steel.
  • Sold individually
  • Works on either side of the vehicle.
  • Proudly designed and made in the USA.
4Runner Rear Window Storage MOLLE Panel | 5th Gen (10+) - Victory 4x4
Looks great! The rack is aluminum?
  • Powdercoated
  • Hardware Included
  • Made in the USA
  • Free shipping!
Wow, love the roof rack and the molle panels for the rear windows! Awesome job. Don’t really “need” an aftermarket roof rack, but that one is so nice and low profile that I’m definitely going to consider getting one. Like others, I’m patiently waiting to see what you come up with for a front bumper insert for the ‘03-‘05 as well!
I would also love to see a full bumper like this one made for the 4Runner. Seems like it would be a pretty simple project to take your existing insert and design the tubing extensions to make it a complete bumper for those looking for that option...
Rock Sliders Now Available!
4Runner Rock Sliders | Strike | 4th & 5th Gen (03+) - Victory 4x4
Our Strike sliders for the Toyota 4runner are designed to be used as a step as well as protect your rig while overlanding, rock crawling, on your daily commute, and everything in between. They are proudly made in the USA and are available in a 2 stage satin textured black powder coat over durable zinc primer finish, or in bare metal.
  • Main structure built from 2x3x3/16" box tubing.
  • 1 3/4" round outer tubing. Tube gussets useable for safe step entry.
  • Made in USA.
Can you guys make an integrated high clearance rear swing out and tow hitch? Something that blends into the stock rear bumper would be ideal
Quick Question(s) about the skid plates. Am I correct in seeing the front engine skid does not use the stock two rear mounting locations? I snapped off one of the rear bolts for my stock front skid so not using them would be a nice benefit.
Also do the skids work well without having the full set? For example if I was just to get the front skid would I be able to keep the stock mid/trans/diff (not sure the term) for a little while with no fitment issues? Or do I need the whole set? Thanks!
You are correct, the rear of the front skid bolts through the cross member with a plate, bolt, and nut. You won't need to reuse the stock bolt location. Our front skid actually replaces the two front factory skids.
This is an old prototype skid in the photo, but you can see the size comparison.
H.Sikina
