Victory Blitz/ARB skids/spidertrax installed
Yeah I just split the wire to my switchpro. I think that took longer than installing the sliders just because of routing the wires and trying to make it look clean.
Gotcha. Incidentally, how did you go about wiring up the rock lights? Victory didn’t have anything on their site, or if they did I missed it.
Yeah victory didn’t have any wiring diagrams. What I did was run a wire from the domerock in the A pillar down through the firewall.
For the lights I connected them all up and ran that wire up through the engine bay on passenger side. Took that wire and connected to the domerock wire. Then from there took all the wires and connected to the switchpro. This allows me to turn the lights on demand with the switch and then also when I unlock from the fob or open the door.
Appreciate it, just to make sure nothing gets lost in translation is there any way you can post a quick diagram? Switchpro has about a 2 week lead time so i just want to get everything pre-positioned for when it arrives.
Victory Sliders
I ordered the Victory 4X4 Strike sliders.
I needed a step for my wife.
They are bolt on to the frame. My driver's side holes did not line up with the frame holes. Tried everything and failed.
Yeah I used this diagram, but didn't bother with a relay
domerockv4_wiringdiagram_switchpro-jpg.3483838
This has some good info on the module where I found it:
DomeRock Module for Courtesy Rock Lights V4 by DSIM Solutions | Tacoma World
Did you try the passenger side? how far off were they?
I got the passenger side on, as the frame holes were mostly aligned with the slider's holes.
The driver's side is another story. The holes were off 1/2 to 1 inch off. Tech support was called, but not much going over there with the Wu Flu shutdown.
I think I'll have to wallow out the holes on the slider and then put a large washer for support between the slider and the bolt.
Ambrose67
