https://www.youtube.com/watch?v=eQ0LyHhtSFk
Hey guys, I've uploaded a very short video on youtube of how my engine starts (don't know how to embed it here, could only copy and paste the link). What's that strange noise? It appears every time the rig has been parked 4 or more hours and definetely every morning. If parked less than that, no sound. Seems to be the chain, right?
No check engine light, no errors - checked with dealer scanner. Low oil level indicator on the dashboard disappears immediately after start so there are no symptoms of low oil pressure. My mileage is 110K. I use OEM oil filters and AmsOil 5w30 or Motul 5w30.
My initial guess was that the chain tensioner (which is activated by oil pressure) is late in providing tension due to abnormally low initial pressure. But then I noticed it started happening sometimes if I press gas real hard and rev up the engine while going uphill - i.e. when I really load on it. The noise also appears for a second, not more.
Anyway, I removed the oil pan and cleaned the oil pump inlet grid and also replaced the tensioner: to no result. The old tensioner is pretty good and its rod is only a third way out of its body - it proves that the chain is not worn / streched too much.
Here's what several mechanics guess: 1) could be insufficient oil pressure - try higher viscocity oil (say 5w40) or different brand; 2) could be oil filter fault - bypass doesn't work properly or something - try another brand; 3) instead of the chain noise it could be the alternator belt rollers or tensioner's noise - replace them (I am of course still running original ones); 4) over time the chain tensioner will move out one increment more and will tense the chain up to the required level and the problem will be gone.
What are your thoughts?
