Vintage Style Paint or Wrap
Bigshankhank
Anyone ever done a wrap on their 4th gen in the style of a 1st gen? I dig the Radwood styling on 80’s vehicles since that’s when I grew up and became a gear head.
The Nautical Blue paint on my ‘08 is failing and starting to peel, so it’s needs help no matter what. No sense in not pursuing a new look.
Don't do this. It looks so bad.
I might replace my white faded side pin stripes on my dark grey paint with a wider, darker grey stripe. I used to have energy to paint cars, but just want them to run now.
One problem with getting a wrap is that your paint should be in good condition.
The wrap will show the imperfections(chips/flakes) underneath.
I would think that most installers will not touch a vehicle that is at the point of clear coat failure.
They want to wrap nice new smooth paint
I've seen cars with clear failure get wrapped, but typically the person applying the wrap sands down any clear peeling first and will make sure that they understand that when they peel the wrap up that it may take more clear coat with it.
I've been going through a similar thing, but it's much more expensive where I live. A wrap could last 3 years or more, with care. Most are warrantied for 3 years, vertical surfaces only. A good, and expensive paint job could last a very long time, again with care. Problem is, someone totals your truck and you're out all that investment. Are you willing to roll the dice on that, or pay for a new wrap every so often. Keeping the T4R for a lifetime? It's a headache I've been wrestling with for a while now. A full on paint job up here, including all but the engine bay, will run $15k on average, with only a few places on which to rely. Wrap job? $7k. Hope your conundrum is easier dealt with than mine.
Cheers
A guy who lives in my neighborhood is the GM of a local shop that does wrapping. A single basic color would run approximately $2k, but he does some side work and might be cool to let me assist to bring the cost down. A coworker of mine had been doing bodywork a few years ago and estimated a decent paint would run in the $6-8 range.
Yes the neighbor mentioned sanding out the failing clear coat, but I can do that, remove the cargo rack and trim pieces myself.
At 230k I am on the fence how long to keep this. I know it’s got a lot of miles left, I take good care of it mechanically but dropping six large on paint is asking too much.
Have you thought about bedlining it? WAYY cheaper alternative, can be done quite easily by yourself even without experience in painting, and that sh** is tough! Plus its UV resistant and can be done in just about any color you want.
Sent from my Pixel 3 XL using Tapatalk
Wrap would be the worst investment. If the paint is already shot put that 7k you have for a wrap towards someone who paints a lot and you will be happy. I had a single coat put on my samurai two weeks ago and it looks good. Mine was under 900
Wow, I can certainly see why you’re at a crossroad. I also never knew that the wrap was that expensive. I know paint prices have gone up ALOT in the past decade or so due to ever increasing EPA regs, surcharges on materials, etc. Have you considered just doing it yourself? I’ve painted many cars over the years, and it’s honestly not that hard as long as you create a reasonably clean space to do the painting, and have the best respirator you can buy for your own safety. Because the last full paint job I did contained isocyanates, I invested in a air supplied, full face respirator. With all of the materials, a new high end hvlp gun, respirator, etc. I was probably in for around $2,500, but it also had expensive tri-stage paint for graphics, and the best clear I could buy at the time. Sounds expensive, but the best price I could find for that paint job was $12k, so not only did a save a lot, but I had the satisfaction of telling everyone that not only did I build the entire car, but I also did the body, and paint.
If you’re not looking for show quality, but just want something that will look good and save some money, just do it in a single stage acrylic enamel with hardner. It won’t have the depth of a clear coat paint job, but is way easier, with less steps, as well as less costly. I’ve never looked, but I’ll bet there are YouTube videos that can help with proper techniques if you’ve never sprayed anything before.
All I know, is there is no way I’d spend the kind of coin you were quoted for either wrap, or a professional spray on a vehicle with that much mileage, especially with wrap having such a limited life expectancy.
I’ve painted bikes before with good results, not show quality but good enough for a daily rider. Doing an entire car would be a challenge as I live in a stilt home and the garage space is open, so it would entail building a chamber with lights and power down there. The primary reason I had been considering the wrap is to be able to add graphics to a wrap and see a render of the final product for less cost than having custom decals made and applied and possibly misaligned. Bed liner is not an option as the wife wants this to look “nice”.
I guess I’ll take the easy way out and pull the hood and drop it off at a body shop, it’s the only bad part, but matching the color against the rest of the car is a trick.
if this were done properly it would be SICK.
wraps r dum
delislerebecca
