Violent shaking when braking
It's really odd that you weren't able to feel the shaking when you pulled the e-brake handle. It must be way out of adjustment. Nevertheless, glad you finally got this figured out.
The brake hoses are fine from autozone etc.....around 15 dollars.
Could you tell me the pros and cons for getting front brake aftermarket brake hoses ($15-25) vs Toyota OEM brake hoses ($100). Do I really need Toyota OEM?
Good brake bleed exchanging the fluid is what you after. It's up to you if you want to use oem rubber flex lines or use aftermarket.. :)
Sent from my SM-A505U using Tapatalk
Also do I need to get a brake flush or is brake bleed adequate?
You'll need to define those terms... They sound the same to me! As long as you don't get air up in the ABS actuator, you just need to get clean fluid through the lines and to the calipers.
-Charlie
Bleeding brakes - just adding lost brake fluid and ensuring no air
Brake Flush - removing all old brake fluid and replacing it with new brake fluid
Depends on the fluid color.. Dark or almost black. Best to empty reservoir and put new fluid in with a good bleeding.
Clear fluid just bleed the brakes for no air. As water an containmenants cause rust in the brake system.
delislerebecca
