Void Warranty with lift?
Ski-Mammoth
Quick question, I'm looking at getting a 2016 or 2017 4Runner, most likely the 4Runner Trail Premium.
I want to add a 3" lift..........does that void my new car warranty?
I love the look of the TRD Pro, but I think I get everything I need in the TP!
you need to look this up...
Magnuson-Moss Warranty Act
Thank you - That's what I needed!!!!
Will using 'aftermarket' or recycled parts void my warranty?
No. An 'aftermarket' part is a part made by a company other than the vehicle manufacturer or the original equipment manufacturer. A 'recycled' part is a part that was made for and installed in a new vehicle by the manufacturer or the original equipment manufacturer, and later removed from the vehicle and made available for resale or reuse. Simply using an aftermarket or recycled part does not void your warranty. The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket or recycled part. The manufacturer or dealer can, however, require consumers to use select parts if those parts are provided to consumers free of charge under the warranty.
Still, if it turns out that the aftermarket or recycled part was itself defective or wasn't installed correctly, and it causes damage to another part that is covered under the warranty, the manufacturer or dealer has the right to deny coverage for that part and charge you for any repairs. The FTC says the manufacturer or dealer must show that the aftermarket or recycled part caused the need for repairs before denying warranty coverage.
matisgugle
