Vsc Check, Vsc Off Lights
retco
Stealer can't find anything wrong when they plug my T4R into the code finder, VSC TRAC, VSC OFF LIGHTS ON. WHATS UP
search "zero point calibration" and download the tsb. it has the instructions to reset your yaw sensor values and turn off the vsc lights. i just did this yesterday and it took 5min to do.
Hey Bro, thanks for the replies. Don't really understand the Zero Point Cal deal, a bunch of codes and big words to me, guess college didn't help me w/ that. Can you tell me what i need, what i need to buy, Sorry, i need things to be alittle simpler THANKS FOR ALL YOUR HELP
just print out the instructions and get some wire... i used my speaker wires since you need two separate wires. you need to put the wires in the obdII connector under the dash. there are two tsbs, one will have a diagram and the other won't. download both and you'll see what i'm talking about. all you do is touch the two wires at certain intervals and do exactly what the instructions say. make sure you are also on a level area.
V8LIMITED4WD, VSC lights off, used a ornament hanger and followed the TSB, saved me alot of money. THANK YOU FOR ALL YOUR HELP
