VSC off light \ TraK and Check Engine light on
Nedlob
I have a 2002 toyota 4 runner Limited and the VSC and check engine light keeps coming on. computer diagnostic gives the codes C1201 (ECM) and P1135(oxygen Sensor) I understand I have to replace the O2 Sensor. Does this mean I have to replace the ABS ECM as well or is there something else I should try prior to replacing it? any ideas of where i could find the ECM?
I got the same VSC TRAC/ VSC OFF problem too. The funny thing is that this started after i took my truck to the mechanic to have my fuel tank and injector cleaned. I have taken it back twice to have it checked again and they keep saying that it doesnt give any codes and there is nothing wrong with the truck.
I dont belive them and i think they messed up something while dropping the tank and cleaning the injector.
What do you guys think? I need to get back armed with evidence
2002 4runner VSC TRAC/ VSC OFF
This was finally resolved on my 4runner by changing both of my O2 Sensors. Once the check engine light immediately went out so did the vsc trac and vsc off. Ironically the Codes went away as well. The o2 sensor had to be from the dealer. The ones ordered from elsewhere were cheaper but did not work at all. Bothe sensors were approx 320.00 and my mechanic charged 60.00 to install them. Not bad at all to get rid of that problem which I have had for quite some time. No need to chane the ECU now. By the way the ECU
must be set by the dealer. Even if I could have found a place to repair or replace, the dealer is the one who can set the alarm code so that it will work with the vehicle... Good Luckjavascript:smilie(':awais:')
awais
Thanks for the info Nedlob. But based on the work done by the mechanics on my ride, what do you think the problem most likely could be? If i were to drop the fuel tank and flush the injector, would there be a chance that i could be tampering with the 02 sensor?
Why did they drop the tank to clean the injectors? That makes no sense at all. Fuel injection service is done under the hood. No need to remove the fuel tank.:confused: :confused: :confused:
Lol! Dont get it twisted 96dcmss. They did two different things.
They suspected that i had contaminated fuel so they had to flush the injectors and also clean the fuel tank.
Eversince i have had the VSC OFF/VSC TRAC light on.
oh ok, got it now. Naija - is the check engine light on along with the VSC light? Only thing I can think of that they may have done is leave a wire, or hose off....or maybe damage a wire or connector......but most likely for the EVAP system, since that has to do with the fuel system.
Just the VSC TRAC and VSC OFF lights come on whenever the truck gets in motion. I really need to know what could have been tampered with so that i confront them with undeniable fact.
I suspect they damaged something and don't want to admit to it.
They same things been happening with my 2001. Mine stated a couple days ago I reset the CPU but it came back. I was looking at the forums; and I know how O2 sensors fix the check engine light but I don't know how they fix the VSC/TRAC lights I really don't want to spend 320 bucks and still have the other lights.
Have you checked your computer for codes? If so, which codes are showing up?
You need to get it scanned and see what is going on. It may just need to be calibrated. There is a thread that tells you how to do it, or the dealer can. Sounds like something is wrong with the calibration, or maybe a wheel speed sensor, or signal problem. Since you don't have a check engine light on, it is a VSC problem.
Most likely nothing to do with the work that was done on your truck, unless there is a damaged, or pinched wire. First thing to do is try the recalibration yourself, it's free. If that doesn't work go have it checked out by the dealer or any shop that is capable of pulling codes out of the ABS/VSC module.
That was a good link Falkon. My problem ended up being that the wife just left the gas cap too loose though. I had a check engine light with the vsc/trac lights. It is weird that all those lights come on together though.
Glad you got it sorted. The interdependencies between these things does not cease to amaze me. Still don't see why a loose Gas cap should disable the VSC/TRAC function of the vehicle. They should make these things more intuitive, I suppose.
Hey Trump Tight.
The way it was explained to me is that once the check engine situation occurs, the system automatically shuts down the VSC to reduce any additional strain on the engine until it can be resolved.
You want to hear another weird one? My wife's Sequoia had the VSC Off and VSC Trac lights come on and the solution was to replace the front brake pads and then disconnect the battery for 20 minutes. All this occurred after putting on new studded tires for the winter. Add to that the check engine light comming on due to oil build up from my K & N on my MAS and you can really screw yourself up trying to figure it out! What a pain.
Check Engine Lights ON, again
We have a 2002 4Runner Limited and we have the same symptoms and originally a mechanic recommended replacing the cat and both 02 sensors. The quote was for $2,000 plus labor and we are not sure if we would like to do this. We went to Autozone to check the error code and the code recommend us to replace the O2 sensors. Well, to date we have replaced both O2 sensors and the check engine light is ON again. We also have noticed that whenever we hit a "BUMP" this check engine lights comes on. PLEASE help!! We need advise soon!
Having this issue....AGAIN....sick of it!
This VSC/TRAC OFF Light with the check engine light all started last September 2010. These lights came on while we were on vacation and had it ran on the diagnostic machine at the local shop. Nothing really was indicated except the catalytic converters. Mechanic told us to just drive it since nothing about the performance was different.
So...I drove it another 7500 miles before they came on again. It was still showing a code for catalytic converter. My mechanic told me to just keep driving it after he test drove it and found it to be running fine.
I drove it another 5000 miles and they came on again. This time, I had the catalytic converters replaced. I also mentioned having the 02 sensors replaced, but my mechanic didn't see the point of spending the money since they apparently were ok. I had the catalytic converters replaced in January 2012.
I thought everything was fine until yesterday.....guess what? The lights are back on! It drives fine....runs fine, sounds fine.
I am curious about the having to purchase the 02 sensors from the dealership....I know that my mechanic will install the sensors, I am just confused as to how to get the dealership to re-set the alarms....do they charge for that? I am assuming so!!
Please help....getting very frustrated!
My vehicle is a 2002 toyota 4runner with 225,000 miles on it! I am not ready to give her up just yet!!!
LE Taylor
Help
So my 06 4runner sr5 4.7 has a check engine light, vsc off, vsc Trac, and traction light on. Had it scanned and is popping P0174, p0171, c1253, c1249, c1246, c1223, c1201 codes. Any ideas.
