Vsc trac, vsc off, abs lights help!
cheez755
I searched and my problem is not like all the other issues. The lights came on after I replaced the front two calipers and pads. I put in a 2.5"level kit and while I was in there I put in ball joints swaybar bushings and end links. Put it all together and the friggen lights come on! Does anyone know what it could be?
I would assume (but not 100%sure) it has something to do with resetting the zero point calibration on your vehicle.
I would search zero point calibration and you can find instructions on how to reset/re calibrate it.
I'm sure someone who knows for sure will chime in, but that's my guess and I'm sticking to it.
I had the same thing but no ABS light when I got my '04 SR5 aligned after a 3" lift put on. I took it to a local shop and got them to do a zero point calibration. The guys there should know what you're talking about. Only cost me $45 with no diagnostic fees!
