VSC TRAK VSC OFF warning light
rsasse
I have a 2003 4runner and recently had the "check engine" light as well as VSC TRAK VSC OFF light come on. Turned out to be an O2 sensor which has been replaced. The check engine light went out but not the VSC TRAK VSC OFF light remains. How do I reset or shut it down before winter?
Unhook the positive post (red) of you battery, then re-hook it back up. If they come again, drive it for a few more days, and do the same and see if they stay off.
I just had this light come on, along with the check engine light. It turned out the cause was a loose fuel cap. Check to see if your fuel cap is tightened properly.
Thanks all for contributing to this thread. Lots to read in this forum but I like it.
My experience is totally different than anything else posted so far in this thread.
Had the check engine light, VSC TRAC and VSC OFF lights come on last night on the drive home from work. Certainly of some concern, but I could not figure out why they came on all of a sudden.
One of the roads I travel home on is almost entirely potholes (gives the suspension a good workout), so I thought maybe a sensor got jarred loose. Also, with the milder weather lately, lots of snow has been melting and there is this huge puddle (make that a mini lake!) at the entranceway to the parking lot at work. I drove through it at pretty good speed and had water spraying over the roof.
Take my T4R into my dealership the next morning to get the OBD codes read. Comes back as a problem with a transmission sensor. The technician clears the code, and all is well. All warning lights go off, and are still off.
We suspect some water got into the sensor (maybe the seal is deteriorating) and the ECU was not happy with that.
I'll try to not treat my T4R like a jet ski in the future :driving:
DJNutshell
