Warm up/mpg gauge
mustangr2
So I normally try to warm up car so it’s not freezing before I get my daughter in the car. Noticed that the mpg gauge shows a pretty big loss of mpg letting it warm up. Like 1 full mpg with a couple of minute warm up. Just curious if anyone else has noticed? I am surprised it dumps that much fuel warming up.
Never noticed, probably because i never look at that gauge. I think it's useless/not accurate and usually hand calculate mileage.
But that said, anytime your vehicle is running it's going to effect mileage. I'm sure long warmups will effect mileage over the course of the entire tank of gas. You would have to run a whole tank with no warmups and then a whole tank with warmups to determine how much it effects mileage.
And we're all running winter blend gas now. It historically gets worse mpg than summer blends. Mine averages 2 mpg less than with summer blends. I didn't even know there was such a thing until I joined this forum........
It’s not that it’s using a lot of fuel,
It’s that it’s adding zero mpg/time in to the average. Adding zero points in any average calculation is going to skew results toward zero
Don’t sweat the average mpg in wintertime. There’s plenty of factors that make it less than ideal. Winter gas, warming up, 4x4, slightly lower tire pressure...
Thanks for the replies. I don’t worry about mpg. I wouldn’t have a 4Runner if I was lol. Just curious more than anything.
You should drive slowly in a residential area for a few mins,then driving on the streets. Warming up is a wasting of fuel unless you just want to warm up inside of the truck.
yeah that is pretty much what it is. Just warming up the inside for my daughter.
Depends on when you reset the MPG. The meter divides the gallons used by mileage since reset. If you’ve been a couple miles then sure it’ll move significantly. If you’ve gone a couple 100 or more then it’s not gonna move at all.
charlesz
