Water Condensation in Fog Lamp Lens!
msanta
Every time it rains or snows or the weather is humid outside, my right fog lamp lens gets moist inside the lens and fogs up(figures...a fog lamp that gets fogged.) Does anyone have the same problem? Have anybody found a solution to this problem? I think that this moisture eventually will cause the halogen bulb to bust. Would the dealer replace a lens because it gets wet inside?:p
you could try warranty.. its probably caused by an improper seal. you could take it apart and reseal it..
I get the same thing, but it also happens in my headlights as well, I notice it every morning but I never give it another thought. It's been getting down to about 30 degrees at night here, which is extremely cold for SoCal, but it warms up really quck and the condensation comes and then goes away fast. I'm going to start watching out for this and I will address it at the dealer next week when I am there. It just never occurred to me that this should not happen and that it could result in a possible problem. Thanks for bringing this up msanta!
I want to check to see if the bulbs are properly seated, I think that might be a possible solution. I don't know what kind of sealant I can use, any suggestions?
