95 4Rnr 4 Grace
Hi Everyone,
I have searched through previous threads and most of them that dealt with water pumps also dealt with overheating issues. The delima I have with my 95 4 Runner 6 cyl (3.0, 22 RE) with 186k miles is that I am not having an overheating, just coolant leaking.
The coolant leak began last Thursday with small, very intermittant drops. Today, there was a puddle of green coolant on the ground. This time it was dripping enough that I could trace the source. It looked like it was behind the water pump (as you are facing the engine) on the driver side nearest to the oil filter/oilpan area. I wiped it down, but it kept dripping.
I am not hearing any noise as I drive or any gurgling once the engine is turned off. My oil is normal - no cloudy, milky look to it at all. My heater runs beautifully, in fact, it runs too well and the guages function normally. I have never run this vehicle hot and have always maintained it with proper fluids, belts, etc...I also had the heads refurbished (valves, pistons, etc) 30k ago and haven't had any problems. I have had it looked at many times since and not been told anything to the contrary.
Naturally, I was nervous about driving the truck with this problem so I took it to the closest shop I could find. They looked at it and said it was the water pump and then showed me that it was leaking (smaller) on the passenger side (as you are facing the vehicle) in the same spot as the other side. They quoted me $1,000 to repair (500 for labor and 500 for parts). They said it would be a 7hour job easily...
I expect to pay a bit for parts and labor, but this sounds a bit much. This truck is in mint condition, except for this, and I bought it with 30k miles on it in '97. I want to do an engine swap someday so I need to watch my budget with the current engine.
Is it possible that something else, aside from the water pump, could be causing the leak? I am going to try to get some more quotes, but I want to make sure that I have an idea of the issue first so that I don't get taken to the cleaners.
Anyone know a good mechanic in Columbus, OH and surrounding areas
Thank you for listening....
Grace
Grace
