Weird brake issue, 3rd gen
cfb2702
A couple of weeks ago, while backing up in my 3rd gen, I notice the brake pedal had a significant amount of resistance, while lacking stopping power. It went away, but resurfaced now in both reverse and drive. Checked fluid levels and all are in normal operating range. When applying pressure to brakes, there is a significant amount of resistance, followed by a gradual release of the backpressure, then the brakes finally begin to apply.
Checked vacuum hose to brake booster and found no apparent leaks. Is the brake booster suspect, or should I be looking elsewhere? It's a 97 limited 4WD with 270k miles. Thanks in advance for any sage advice.
Sounds like the brake booster check valve. I had the same thing happen to me and it was the check valve. 5 minute repair and 20ish bucks for the part.
...I have done a lot to chase the low brake pedal issue and it is still low lol.
I believe that is a Feature of this trucks! All vehicles are different, especially these, haha.
Mine always has been 'low', yet if depressed enough it will grab on enough to actuate the antilock system, so i know it works as intended.
AndiGarage
