Slowrunner
So I have a '05 SR5 V6. Normally, I can keep the inside temp. setting at 72 and be very comfortable, other than on a hot day, or a cold day, just to get the cab comfortable quick, but then 72 will do it. Last summer on a hot day it would work well and I would put it at around 68 most of the time. In December, while driving through Colorado, maybe 45 degrees out, I noticed at 72 it was blowing cooler air than I would have like...noticably cooler. Not a problem, just turn up the temp setting and the heater worked, just now 75-77was a better choice. In the spring once the weather started to warm up, I found that the thing worked great in the morning when the sun was coming up, but once it was up it would blow cold air all day. For example outside air 65, inside setting 72, cab felt comfortable but air coming out of the vents was cold enough you wouldn't want it blowing on the steering wheel. The dealership told me the computer was showing nothing abnormal, it wasn't a problem they ever see and I may just have to deal with it.
Now I know the air temp at the vents isn't the same as the temp it is trying to reach in the cab, but normally once the cab is at the temp, the air in the vents just matches it pretty closely. Now that summer is almost through, I haven't once set it below 74, and generally cruising on the highway for a road trip it is set at 77, still cold air coming out. I know this can't be right. I live in the desert, and I know I am probably the only person complaining that the air conditioning works too well, but I really can't get a comfortable temperature in my 'runner like I used to.
Anyone else have this problem? I'd like to have something to suggest to the service writer next time I take it in. My extended warrenty is out in about 10,000 miles, so I'd like to get a good paper trail on this thing now.
I feel like it could be a faulty sensor, computer etc. but maybe something mechanical like the blend door is jambed? Sorry for the long post, and thanks for any help you guys can give
