Weird noise when I hits the brakes
lcbjr77
Hello I just started noticing a weird sound.
Vehicle is garaged...I get in my 4Runner, start it up press the brake to put in reverse the next time I hit the brake to ease out of the garage I get a loud knock sound. Then the rest of the day I never really experience it again.
I was thinking maybe it was a caliper, any input would be greatly appreciated.
Thanks for the response, I did that about 2 months ago (I was getting that surge while at a stop light)... I was told there were 6 on the rear shaft after investigating could only find 3, I guess there's a front shaft that has some also....????
If I get some time I'll shimmy under that hit them all up again.
Sounds like you need to grease your drive shafts. There are zerk fittings for the u joints and one for the shaft
I did the rear brakes myself back in April, I greased the pins and used all hardware that came in the box. I also took a wire brush to the caliper brackets before putting everything back.
Thanks for the feedback folks, I'll pop the wheels off tomorrow or Monday and see what I can find
