Weird tremble/ hesitation around 25 MPH
GTOchris
Hi,
I've been lurking for a year but haven't had a reason to post until now.
2005 4x4 4.0L 4Runner SR5, I'm the 2nd owner- bought it last year with 64K and now around 72K.
When accelerating steady- around 25 mph I'm getting a bit of a slight vibration- feels like a cross between a mis and too early of an upshift...
Since it is used- I'm not sure if the spark plugs are original or not- however shouldn't they be good for a bit longer? Do these vehicles have an accessible fuel filter I could access and change?
Really like it in most every other way:)
Thanks!
-Chris
The plugs are due. The OEM plugs are just Copper plugs. They only last about 50k miles. So you are actually PAST DUE.
I'd start there. And I suggest you replace with the standard copper plugs also. There's no need for Platinum or Iridium plugs.
Thanks-
Should I do wires also? Are they reasonably easy to do on the 4.0L or should I pay someone for fear they might snap off? Any other items to get tackled at the same time?
Coincidentally I was at a Toyota dealer today swapping a work car so I picked up some OEM sparkplugs, I'll probably have my regular mechanic change them for me soon.
I don't think I have quite the "rumble strip" issue however I might get the transmission flushed soon due to the mileage and I tow and midsize boat.
Thanks!
utkrstam
