What A Deal?? Fj Lift??
T4Rsoldier04
Ok, Remember I am fairly new here.
I have been told that the FJ rear suspension can swap over to the rear of my 04 sport, but what about the front - here is why I ask!
"6"/4.5" Front/Rear Ride Height for 2007 FJ Cruiser 4WD w/ Box Kit - EXP-K5067BMX Coil Over Upgrade Kit Included With MX2.75c and MX6 Shocks "[/U]
Price: $566.08
Sale Price: $526.61
(MSRP $3,461.32)
I would jump if it would work!!
http://www.4wheelonline.com/Products.aspx?CategoryId=52804&ProductId=127224
Price: $566.08
Sale Price: $526.61
(MSRP $3,461.32)
Sorry to be the bearer of bad news, but it appears you may be reading it wrong. The lift w/ MX shocks is $2265 (discounted from $3,461). You must add it to your cart to see the price. The $526 sale price is for the replacement front drive shaft that they recommend if you want to drive on the highway in 4wd. The lift with ES series shocks is $1447.
Hope that helps!
The fj and t4r fronts are very similar and that lift can be made to fit with minor adjustments here and there. Look for a thread called 7" 4runner, that guy, alexjet, did exactly that with fabtech fj lift parts.
josh220 said:
Why not just look into a spacer lift? 1"/2" or 2"/3" both look great.
A spacer lift is just for looks and does nothing to improve the performance of the oem suspension which I personally found to be too soft for my taste.
ha ha
Plus Josh - I was talking about a a coilover kit that would be excelt off road and gave 6 inches of lift.. why would you suggest a spacer kit in the same thread?? LOL - I was going to do spacers, but I offroad ALOT and have decided to piece together a lift made up of mostly OME stuff
I didn't know you wanted 6" of lift. Alexjet was the biggest lift i've seen on here and he has a 7" custom lift, so it didn't occur to me that you might want a lift close to that big. My bad.
Haha we have a comedian. :D
But are you sure it's not more like "Awww it's cute"
Just kidding. When are you lifting your truck? I wanna seeeeeeee.
Should be next week or so.. Before Dec 23 is my Goal. I actually just got off the phone with ToyTec and I am going a different route in the back. I am going to use their springs and the ProComp shocks as their springs are longer and softer than the OME. I have no need for the stiffness of the OME since I have no plans on carrying that much weight, besides my two 90lb dogs occasionally. So the springs are longer and the OME shocks are not, which would no allow any greater flex than the stock setup, so I am going with the ProComp on their recommendation, plus they are only $89.99.. which is even better than the used pair of 141 OME for $100 I had planned on getting.
