What are these and where do they go?
skippy-c
I found both of these unhooked and suspiciously close to each other. Should they be plugged in and what do they do?
[/url]
DSCN5598 by scottclyatt, on Flickr[/IMG]
Yes it could definetly cause it to run bad and should give you a check engine light. You can either fix the sensor or bypass the egr all together.
sensor
The sensor measures temperature of the EGR . It sends a signal to the ECU that the Temperature is in the correct range. It serves no other purpose then to report. If you have a engine code 71 a 10k ohm resistor into the the plug will fool the ECU that the EGR is within normal parameters.
The EGR functions as a fire extinguisher to cool the engine temperatures while in certain engines modes ( coasting ) During start up or WOT the system is suppose to be closed.
goddesszilla
