what button is this?
itsmemaaaark
sorry for the dumb question but i couldn't find nothing. i don't even have the owner's manual. but what is the green square button below the shifter(auto)? the letters on mine are faded. i press it once in a while but i don't feel a difference or change in the way the car goes. what is it used for?
Mystery button
I have two buttons on mine ( 1990 SR5 ), not sure which one is the green one tho.. One is for the Atomatic Transmission Mode, it toggles between normal and power. The other is called rear windows lock. Try pushing it and see if the rear window still operates. I'll check the labels on the buttons tonight.
I never use these :P
thanks for the quick replys. yea when i do press the button i think it raises the shift points. i also noticed that it uses more gas in this mode right?
ToyotaDoodz said:
The ECT button changes the shift points, not the overdrive button. ECT causes shifting at higher revs. Overdrive simply allows you to use top gear but does not change shift points.
Yes it is the ECT(electronic controlled transmission)button
the Overdrive button is on the side of your gear shifter.
When ethierone is pressed the dash will light up "ECT" or "OD off".
my ect works but it doesn't light up in the dash
*well i got the light to work today. all i did was d/c the battery then connected the batt. and wala
my uncle showed me all of that when I got my 4runner. its a really great feature for hills.. he taught me to turn the Over Drive off before turning the ECT on... it really helped me out today... going to Newport and back...
Question
I have a 1995 toyota 4runner. I am wondering what the button on the shifter it self does. It is an auto. So does anyone know what it is? It looks like 0/0
I believe that is the overdrive button, It has been a long time since I have owned an auto though.
When ether one is pressed the dash will light up "ECT" or "OD off".
Nice job digging up a thread from 04. even if your answer was only a couple posts up.. And it says O/D (over drive)
