Hey guys, well I was wheeling with some friends on Friday and as I was attempting to get over one of the obstacles, I heard a nice loud "pop" and lost power up front. My first assumption was I snapped a cv axle...but it appears that this might not be the case. I took out the axle, but the outer part(where the cage is with the bearings) is not broken at all. The inner part that snaps into the diff is still in the diff... We left it in to keep it sealed. We were afraid I may have sheared the shaft in the diff, but now we are not so sure.
If it was sheared in the diff, then the inner part that snaps in should be easy to remove right? If it sheared before the snap ring on the splined shaft then only part of this would come out. Well it wouldn't budge when we tried to pry it out, so it appears that the inner half of the cv may still be intact.
We looked at an exploded diagram of the differential, and it appears there are 2 shafts inside the differential that in turn spin the cv alxes. What are the chances that one of these are broken?
When i jack up the front driver side, and spin the front drive shaft, the front driver side should spin because this is an open differential. The easiest side will turn, correct? Well, when spinning the drive shaft, I am able to hold the inner part of the cv shaft, and prevent it from turning. So if the drive shaft is spinning, but the inner section of the cv shaft isn't, wouldn't that mean somewhere in between is broken?
We thought that I may have blown the front diff gears, but I drove home with 2 shafts in, so the wheels would turn the shafts, which would spin the gears in the differential. I thought if I messed up the gears some sort of grinding or noise would be heard, but it is not. You can sort of hear the gears meshing if you spin the shaft, which doesn't make much sense that they would be messed up.
At the moment we are thinking that one of these secondary shafts must be broken, but i have never heard of anyone having this issue. Most people just say the cv broke, and replace it...
I have some friends that will be helping me drop the diff this week to see what went wrong, but i was just curious to see what anyone else thought?
** I realize this may not make much sense, so if you are not understanding something let me know what, and I will try to explain it better. I will try to get pictures in a few days.
