What did you pay to have your spark plugs replaced (V6)?
pipspeak
Member
Curious what folks paid for 6 new OEM plugs installed by a shop. I cannot find a stealership that will do it for under about $400, which is a ludicrous price for six spark plugs and what looks like a half hour job.
Sadly I cannot do it myself, but if I can't find anywhere that'll charge a reasonable price I might just buy the tools etc. and borrow a friend's driveway (although torque wrenches are a bit pricey)
Why can't you do it yourself? You need a few tools and a torque wrench from Harbor Freight is $10. Everything you need can be bought there if you don't have any tools. It should take you less than an hour to complete.
To answer your question, $60...
Why can't you do it yourself? SUPER easy. Just don't be that guy and remove all spark plugs/wires all at once. Just do it one at a time.
Tools? All you'll need is a wrench, extension, spark plug socket and a gapping tool(just incase). At most you'll spend $20~25.
I changed all 8 on my ‘05 V8 and it took me 30 minutes tops. Not really a hard job and don’t need a lot of tools at all. Anywhere you look is going to charge you a lot since they consider it a “tune up” on a vehicle
$400 sounds about right at the dealer. An independent shop would probably be closer to $150 around here, but probably more in NYC.
I paid PepBoys about $25 for the six NGK plugs specified in the owners manual and it took me 40-50 minutes, including obsessive cleaning and compressed air blowing to make sure I don't drop dirt down the plug hole. However, I realize that not everyone is comfortable wrenching on their engine, or is physically able to do it.
I could do it myself, but the tools plus other bits and pieces (antisieze, grease etc.) would probably run me $60+ and then I'd have to drive an hour to the nearest friendly-friend's driveway/garage (I live in a city apartment and park on the street), so if I can get it done for a half-hour's labor (ie about $60) that would be a lot less hassle. Surely there must be some shops that charge a normal amount for a simply job like this?
You can do it in the Harbor Freight parking lot after you buy the tools. I don't think you'd find a shop that charges that low.
$60? Where are you getting your prices from? It'll cost you at most around $25. You can get those little $1 packets of anti-seize, and di-electric grease from O'Rileys at the checkout counter. Gapping tool for $1. $5 for a spark plug socket, maybe $15 on a ratchet, and another $5 for an extension.
I live in a similar situation as you. I still wrench on my truck on the street. Technically not legal... But hey, it's only illegal if I get caught... :rofl: And it'll only take a few minutes...
As stated, buy the tools, work on the truck in ANY of the parking lots. Autozone, Walmart, ect.
The leg work an thought you've put into this has already surpassed the time it would take to do the job. An do yourself a favor, just spend like $50(?) on a tool SET from Harbor Freight. Get ratchet(s), socket(s), extensions, so you aren't buying individual stuff for one specific job.
OK, you convinced me... but I'll invest in a decent torque wrench though because I could do with one anyway for other stuff. Off to YouTube I go for research!
The leg work an thought you've put into this has already surpassed the time it would take to do the job.....
Yup^^^
Spark plug job is a "clean" no-mess job; No one should complain about it.
That's the spirit! (I have more peace of mind when I work on my truck myself.)
Torque wrench is surely a good investment. Got a Kobalt one from Lowe's.
With spark plugs, a legit alternative to torquing is to screw in the plug by hand (with socket and extension if needed), feel when crush washer makes contact, then with ratchet this time turn a certain fraction of a turn further. This may even be printed on spark plug package.
Don't waste your money on a HF tool set.. Home depot and Lowe's occasionally has sales for their tool sets, that are really good deals. They have one right now.
Hell OP could get this: https://www.lowes.com/pd/Stanley-68...c-Mechanic-s-Tool-Set-with-Hard-Case/50435042, AND a spark plug tool for like $35. That tool set will do at least 99% of what you'll need to do.. The other 1% are just specialty tools, that you need once in a blue moon that you can rent out.
Just did this the other day and it was super easy. On the driver's side, I removed two hoses and the big vertical bracket. It'll all make sense when you see what things to move out of the way to give you access.
charlesz
