what do u think?
vinnysrunner
i just had terra grapplers on 265 70 17 and i want to make it level in front. i pull a trailer and i know there are tons of kits. i dont know which one to get..... i have researched for a long time now and dont know which is best. thanks!
Kinda depends on what you plan to do with your rig. If you aren't planning on any off-roading, more then light off-roading at least, then you should be fine with something like a daystar or cornfed leveling kit.
As R8R said, mission definition is really important. I would say based on towing a CF 1" net lift spacer or the Toytec .75" lift levelling spacer would be a great answer. Preload or top-spacer? IMHO when lifting in the 1" range it doesn't matter much if at all. When lifting beyond that ride can change a bit based on spacer design.
I'd consider Airlift or Firestone for the rear. 1 link in my sig, another here.
I am looking to get rid of the rake without the trailer on the back. thanks for the replys do you all like the cornfed or daystar more i was thinking 2/1 lift how would that look with my tires.?
delislerebecca
