what fuilds are you guys using?
smokey0066
First post here. I never knew there was so much out here for this truck. I'm about to crawl under my truck for the first time to do the diffs, a/t and xfer case oil after reading a write up online. I think i could save myself the 250 and do it myself.
What kinda oils are you guys putting in the three gearboxes? i've heard I can just go with mobile 1 syn gear oil 75w90 in all three housings. i'm going to go and spray the six bolts down right now to hopfully easy their removals.
also what is a good A/T fluid to change with if i drain the pan too? hopefully someone will respond and I'll wait before going out to pick up fuilds.
thanks guys. hopefully i can save some cash for other toys
A/T??
what about tranny fuild? i didnt see any on the shelf at pepboys or walmart.. do i have to pick up tranny fuild from the dealer?
I'm not sure on the tranny but I'm pretty sure you are not limited to just Toyota stuff. Check out your owners manual and then Amsoil.
