sant6236 said:
Ok, I will take your word for it.
I will connect the P Contol (Blue & White) wire coming out of the back of the deck to only the remote wire (Blue) coming out of the amp.
This will activate the amp and sub for DVD/CD, but then how will the Tuner/FM/AM get basS from the amp and sub? What activates the amp/sub for the Tuner?
Its ok to run all of the grounds/Ebrake wires together correct?
Also, how abot ALL power wires, would this be a problem?
No, I did not just splice speaker wire and mute or ILL into anything and everything, Im not that bad, funny though.
Your deck will be much happier!
Again, the blue/white wire provides a turn-on power to the amp as long as the deck is on. So it doesn't matter if you are listening to a CD, DVD or the radio tuner, it will provide power to the amp. The blue wire only provides power when the deck is set to tuner (which would be the only time you need the antenna up, or on anyway).
As funny as it may seem splicing all the speaker wires together, I've seen some pretty stupid stuff over the years.
I've had to bite my lip many times. I've looked on in disbelief more than a few times when the person approached me wondering why they have this horrible hum, static, or even why they had smoke coming from the radio when they turned it up (yes, smoke). Then I check out the install and find a rats nest of wires, no actual splices or solder used (just twisted together), and may or may not have tape or heat shrink over the bare wires. Yikes! Oh, the good old days LOL.
Anyway, the ground being tied together with the e-brake won't be a problem (other than being illegal to do so). Now, the power wires tied together may not necessarily be a problem, but may cause undesireable operation.
Such as, if you tie the battery & accessory wires (red & yellow) from the deck together, and splice into a hot (battery) wire, then your deck will always have power, may run down the battery, you will always have to manually shut it off, will probably stay pretty warm or hot (temp), and ultimately, may fail prematurely.
If you connect the red & yellow wires to a switched power source from your vehicle, then your radio station presets will most likely erase each time you shut off power, your cd or dvd will most likely always start from the beginning each time instead of from where you left off when you shut the vehicle off. You may even have to go in to the menu each time and turn on the sub output, or adjust EQ settings. I don't know about you, but that would drive me absolutely nuts!
Once again, they give you the wiring information so you can connect it as they intended it to be connected - CORRECTLY. Wire each wire to what it was intended to be wired to, and you will enjoy your purchase so much more. If you skimp or take shortcuts, you probably won't enjoy it as much, and may even shorten the life of your deck.
Good luck again, & let us know if you have more questions.
