You understand im trying to get everyones opinion even though I think I will probably go with the true flow. Is the K&N and The fram airhogg Gause type air filters? Oh and does trueflow make an intake kit?Elton said:trueflow hands down
Rob96 said:OEM for me.
miles said:I thought the paper filters were not that great. Will someone explain why yall are using the oem filters? Is it bad to use an aftermarket filter?
Also: for ecu response. not sure how long it takes. I heard one full tank should do it. I recomend taking out the ecu because its performing as if you hadn't done the mod and therefore its basically like adding extra air but not changing the performance. I've actually taken it out a couple times because when i first did it was flying around everywhere and wasting gas like heck (i get like 12-13 mpg on average, basically what i got before the mod but i go faster now). I take it out basically when i change my driving habbits. When i stopped flooring it all the time i started noticing harder shifts and after resetting the ecu it was better.
What is the ecu? Im not sure what that is? How do I reset it?87&00-4runner said:Did you remember to reset the ECU? Here's a quote from a thread about this mod/subject of deckplate....
miles said:What is the ecu? Im not sure what that is? How do I reset it?![]()
Your year/truck might be in a different location, there's a fuse box by the drivers leg and one in the engine bay, just gotta fine the ECU fuse and unplug it for a minute or two or do what others do and just disconnect the negative battery terminal maybe for 5 minutes, just that doing it that way you have to reset the radio/ clock, it's just as if you were clearing a cel code, unless you never had to clear a code, but basically that should be it :bigok:The ecu: open the fuse box, look on the inside and it should tell you. I have a 98 and on the left side of the fuse box (if standing at the front of the vehicle) has like a 20amp fuse with 3 15amp fuses below it. The middle 15amp fuse is for the ecu. Check the fusebox diagram tho (should be stuck onto the inside cover of the box or in the manual...also search this site and yotatech.com forums if you don't find it)
