Yes, I have auto air, but I dont get why the auto a/c needs to know how bright it is outside. I thought the auto a/c uses a temp sensor in the cabin....
IF that is infact the ambient temp sensor then they usually put them up by the windshield because thats where it's the hottest.
I cant pop up Ligs link he posted to see what thats all about. Filters on my work comp wont allow me to some sites.
It just says:
It is part of the automatic climate control system. It senses the intensity
of the sun coming in the windshield (and subsequently beating on your chest
and face) and adjusts the temp, fan speed and sets what vents to actuate in
order to cool down the front of your body!
I just checked lignum's link, and I disagree. For once, in auto mode the ACC only uses the "in your face" vents unless windshield defrost is selected. It does not switch between vents regardless of temperature. Plus, even in auto mode the desired temperature has to be manually input, so even if its 100 degrees outside, the a/c will only blow cold air if you tell it to. If you select "hot" it will comply and blow hot air. Thus I don't think the auto air uses the sunlight-intensity sensor to independently determine how cool to make it or which vents to use.
Guys.... Isn't that the Warp Speed button...
Duh? lol...
Had that pretty much figured out off the bat. Question is (or was), what does it run/manage....Ha, I was way off. Toyodiy says it's the THERMISTOR, COOLER (SOLAR SENSOR)
