briandunning said:
I guess my question was a little more specific: I know it's a solid rear axle, but which one, what kind, how strong?
Wow, it took you a whole year to respond!!
The axle is a Toyota 8" ring gear axle, common on Toyota 4runners, FJ Cruiser, GX470/Prado, Tacoma, and previous pickups. I have read that the axle tubes are welded to the diff housing and reinforced. It is a good axle, probably around the Dana 44 strength, maybe a bit stronger.
Unfortunately, nothing in life is perfect. There have been some horror stories of Tacoma owners with rear locker breaking their rear axle (even with stock tires)...stripping the gears or something. And there are a few stories about FJ doing the same thing due to same axle and locker design as Tacoma.
Most Tacoma/FJ owners believe that the Toyota 8" rear axle was excellent in the previous generation where engine power and curb weight were modest. However, due to recent pumping up of power (bigger & more powerful 4.0L V6 engine) and heavier curb weight, the Toyota 8" rear axle does have it's limits. The overseas Prado with rear locker also has stories of blown rear axle due to stress.
Here is a good summary thread on this topic:
Factory Locked Rear Differential- problems&solutions - IH8MUD.com Toyota Forum
How does the axle do on 4runners?? Well, i have personally heard of just one instance of someone breaking their rear axle. It is not common in 4runners and GX470. Why? Well, 4runners and GX470 do not come with rear locker, which puts more stress on the gearing teeth of the axle. Goodtimes on this forum have put on big tires (35" or more i think) and his axle is holding up well. But, then again, he does have ARB locker, which seems to help strengthened the axle.
So, if i had a 4runner, then i would not go out and run big tires (anything above 33"), which is a good idea anyway since there is no gears available to re-gear for the big tires. And if i wanted to run bigger tires, then i would get ARB locker. If i had a FJ or Tacoma, then i would NOT get the rear locker option...instead, i would buy ARB's unit.
