vision-quest
As the title says, I'm wondering what size Thule bars will work with my CVT rooftop tent? I don't want to have extra hanging over the side, so I'm hoping 50 will do fine, anyone with experience used this setup before?
Unless you need them for other purposes, just go without crossbars. I mount our CVT Mt. Shasta directly to the roof rails, its simpler, sturdier, and lower profile than with crossbars.
No issues with the stock bars being too weak?
Luc r I think RunnerAK was referring to using the stock RAILS(running front to back) not the OEM crossbars(running side to side).
How much of an issue did you have getting the nuts off that? That's the issue I have with using the stock, just such a pain in the ass.. that's what I was hoping the Thule crossbars would alleviate.
No issues at all, the outer nut on each clamp has plenty of clearance for a wrench since it is outboard of the OEM roof rails. To take the tent off, I pop the black plastic cap off of the tent-rails, remove the outer nut from each clamp, then tilt the tent up on each side to slide all of the clamps out of the channel in the tent-rail. After that, it is just a 2 person job to lift the tent off of the roof, takes 15-20 minutes tops.
Reverse the order to install (the inner nut on the clamp has to be pre-threaded onto the bolt with the clamping bar since there isn't much room to reach in there once it is on).
Note that the tent's rails have to be mounted perpendicular (side to side) to the OEM roof rails (which run front to back) to mount it like this. The tent-rails are acting as your crossbars in this configuration. CVT provided no instructions whatsoever with our tent, but Tepui has a good installation video on their website which describes both mounting orientations for the tent-rails.
Oh now I understand.. it looks like with the orientation of your tent you have it opening out the back correct? That's why it's much harder for me, because I had it mounted to it opens out the side, which puts the tent rails inside of the car's rack and massively restricts access to the nuts.
