What lug nuts do you run?
ghser7
I have some Teflon Mojaves on the 4Runner now. I ended up reusing some lug nuts that were already on the truck when it came with some chrome 20s. The problem is, it's a very tight squeeze to get the socket in to take them off. Also, I wanna get a different color and nicer/better quality lug nuts in general.
I'd like to stay away from open ended ones.
What brand/style lug nuts are you guys running on aftermarket wheels? :bigok:
Im running the blacked out gorilla spline lugs. You just need a set of 12x1.5. Picked them up at my local discount tire for $37
I picked up a set of the same wheels with Muteki spline drive lugs.
I read these lugs on Wheelers were recommended:
Black and Polished Alloy Toyota Truck Wheels from Wheeler's Off-Road
Although I don't particularly know what bad things would happen if you don't use ET lugs, besides the obvious less thread engagement thing.
In lieu of starting a new thread I wanted to see if anyone was running Gorilla 91138BC lugs on the ATX Mojaves and if they had any fitment problems?
The ONLY reason I ever heard of people getting different lug nuts is looks. In 40+ years of driving cars I've never seen or heard of a Lug Nut failing. So I don't know how you could get better quality.
You need to get the ones that fit your wheels. There are several different styles of lug nuts. Buy the wrong ones because they look better and you may someday see your wheel passing you by. Check with the manufacturer of the wheel, not the internet.
To answer the OP's question, a spline drive lug has a smaller OD which makes it easier to install in the tight lug cavity of some wheels.
So yes, 12x1.5 in a tapered seat or acorn bulge. I can't remember which seat those wheels have.
This might help. (large image...)
http://www.checkpoint-safety.com/si...files/product-images/sphcon_vector_types2.jpg
There are a variety of brands, Gorilla is fine. I have black spline drive Gorllias on my truck.
The reason they're fine and not awesome is the grooves that the key engages the lug.
As you can see, they are rounded, and not very deep.
172915d1349363785-fs-gorilla-black-chrome-spline-drive-e-t-ultra-style-conical-lug-nuts-lug-nuts.jpg
But they work....
If you want the best of the best (with honors,) McGard Spline drive are the best out there.
mcg-65357bk_w-jpg.218914
The base spins, so it won't gall your wheels and as you can see, the area where the key engages the lug is much higher tolerance with more surface for engagement.
Its $35 vs ~$120
Also there are aluminum lug nuts available, generally used on "tuner" or custom import cars, there are a metric ass ton of styles, colors and variations. I bought some for my truck in red, because I thought it would look cool... ;)
But one completely stripped out without any effort because one of my studs was mucked up. I had no idea until I pulled it off... and I did them all by hand. Aluminum has its place, but I wouldn't trust them on a 4wd application.
You know they do make a thinner wall socket, I think gorilla sells it. Make sure to use the right lugs for the wheel. I myself use the e/t conical seat style for my rims, tirerack sent me those with my wheels along with a new socket for it.
Thanks for the replies guys. I know the Toyota requires a 12x1.5 and the ATX Mojave's require a 60 degree taper to tighten. The only thing I'm nit sure is if ET style lug nuts will benefit it or not. I'm concerned if the acorn bulge style lug nut will be too big to fit in the allotted space for the lug nuts.
Just ask the people you ordered the wheels from. I just let them tell me what I needed, who did you order from?
I don't know if I'd ever trust aluminum lug nuts... I feel like they'd strip out too often and really is the like 1-2 pounds of weight saving really worth the hassle? Why not just use those little clips GM uses to secure the brake rotors on during manufacturing? :P
I still have the stock 18inch Limited wheels so I believe I still need a lug nut with the mag seat type and washer like the factory ones. The only problem is that I have had two different sets of the factory chrome covered lug nuts and they both have begun to rust when the chrome cover gets cracked and water gets in there. They look horrible. I want to upgrade to a stainless lug nut or something that won't rust so easily. Anyone running a different brand lug nut on their stock wheels? I have noticed that the Tundra lug nuts of the same generation as my 4Runner don't seem to wear as bad or rust, but I am not sure if they are compatible.
So I take it these are the same but different in a way? I'm just trying to learn the way of 4Runners lol. I didn't realize how spoiled I've been to own a '99 SR5.
if your aftermarket wheels can take the e/t lugs, use them.
only way to find out is put the lug nuts on and see if they will go through with the wheels off the truck. do not use e/t lugs if they wont go through holt holes, youll end up damaging the bolt holes on the wheels.
most wheels have the standard 60 degree acorn seat.
utkrstam
